It is currently Thu Aug 07, 2025 8:31 pm
 Post subject: Head Stock Thickness
PostPosted: Mon Jun 22, 2009 5:35 pm
I was just getting ready to put on the tuners ans the nuts didn't fit. I measured the thickness and it was at .680 and the finish is already done. What is my options?? Do they have gold nuts that I can get that are longer? They are Gotoh 510 tuners in gold.
I never thought of checking the thickness of the headstoch as they were cnc'ed John Watkins and I never had an issue with them before.
Thanks Gary
 Post subject: Re: Head Stock Thickness
PostPosted: Mon Jun 22, 2009 5:58 pm
If you can sand it down toward .600 it will fit.
Gwaltney Guitars
PostPosted: Mon Jun 22, 2009 6:06 pm
I would but the finish is already done. Anywhere to get washers that are .025? these are .060 thick.
Gary
PostPosted: Mon Jun 22, 2009 6:15 pm
You might get away with sanding the washers down if you can't find any.That should do it.I always mount my tuners before i finish to make sure they will fit to avoid this problem. ;)
PostPosted: Mon Jun 22, 2009 6:54 pm
Gary
PostPosted: Mon Jun 22, 2009 9:06 pm
Last Name: Lewis
City: Newnan
State: Georgia
Zip/Postal Code: 30265
Hi-
You could drill a shallow, wide counterbore in each tuner hole almost the same width and depth as the washers. This would make the tops of the washers almost flush with the peghead veneer.
I don't know if this is a commission but if this is for yourself this might be a good option. I like the look - check it out here on Kent Everett's gallery page - http://www.everettguitars.com/guitargallery.html.
Good luck-
John Lewis
PostPosted: Tue Jun 23, 2009 3:07 pm
First name: Nelson
Last Name: Palen
The underside of the hex on the nut can be faced a little thinner if you know someone handy with a lathe.
The washers can be faced a hair thinner also if you're needing just a little. I think .687 is just borderline with the 510's.
I do like the look of the recessed hardware mentioned above but I would hate to try counterboring after finishing.
I could see some advantage also in that any finish lifting from overtightening might be invisible.
Probably would have to use a nut driver to tighten them if the recess was too deep for an open end or box end wrench?
PostPosted: Thu Jun 25, 2009 1:45 pm
First name: Nelson
Last Name: Palen
Gary, you had asked originally if longer hexnuts were available. Shane Neifert had tried to get some longer ones from his Gotoh wholesaler a year or so ago.
No luck.
Might be a good product for an aftermarket supplier?
I had looked at making some at one time but would require a special die or single point thread cutting on the lathe.
Then there's the cost of plating.
Nelson
